Thought I started a post on this, but...Car started running rough, mechanic says #5 injector is out. I would appreciate suggestions about what I should take care of while plenum is off. He found a leaky fuel line and will be fixing that, can they check to see if the other injectors are ok? My mechanic said not much he can do, injectors really don't give warnings that they are going. Also have leaky power steering hose (clamp) he'll take care of. Again, thanks for your advice. Even if I don't take it, it's comforting to hear the points of view. A bit of ammunition I can use for leverage with my mechanic.
Thanks
PS I don't have the funds to do an under plenum job completely. If there are priorities of things to do in that area, it would be appreciated. BTW, found a mouse nest under the plenum. Don't think the mouse knew what he was getting into
