amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Sun Jun 25, 2017 4:06 pm
On most EFI systems the pump is usually the problem. At 10 psi the regulator isn't even doing anything, they don't LOWER psi per se, they LIMIT it. At 10 it is simply waiting for the number to come up to begin to limit it. Dampers rarely cause trouble too. It's almost always the pump and if the original then you are not wasting money at all even if it turns out to be other.
If they run ethanol in your local fuel look hard at that too, it reinforces what I just posted by like 5X. The ethanol eats the pumps in various ways.
If you have phase separated fuel in tank from sitting you are only making things worse.
