So here we go. Hoping some of you guys can help a fellow out. These past couple weeks, 93 Z32 2+2 has been starting up real funky. I'd start it up and it would bog as if its about to turn off but didnt, atleast not a couple weeks ago. Also, it has been having a rough idle, mid 1500 rpms and it takes a while to regain itself, but the second id start driving,idle would go back up again. So a couple days ago, my Z decided to not start up completely, crank, crank, crank, no start. All lights go on, dash, headlights, even my alarm dings, but just wouldn't start. Had to go to work still so ended up taking my girlfriends car, came back, and it started easily... WHAT
Anyway, this morning, it did the same thing. All lights light up, alarms dings, crank but no start. Idk if this is coincidence but my fuel gauge has been acting up. Stays on E until about 10 mins of driving and it goes back to normal. So back to this morning, i did some research and here is what i have done so far. I have checked the CAS, works fine. Checked PTU harnesses and cleaned them out because they were corroded but still didnt seem to work. Finally i checked my fuel filter, took off the hose (after about 15 mins of struggling) turned the key to ON but no fuel. Im convinced that it is probably the fuel pump. I recall, when it was working fine, anytime i would turn the key, i can hear the fuel pump behind me for a couple seconds and now, i dont hear it either when i turn the key. I am a rookie when it comes to doing mechanical stuff but i can work my way around a thing or two. I enjoy working on my own car and so i am ready to replace the fuel pump, however, it is not that cheap. Looking at about $200 from local autozone. I just want to get your guys' opinion before i purchase the part because if i buy the part and car will still not start, i will be frustrated as i am a college student balling on a budget lol. I love my car to death but she has not be treating my right lately. Let me know what you think as she is my daily and have had to miss work a couple times. Thankfully, it is almost the end of the week so i can work on it, just have to find a ride to work tomorrow. Idk if im missing out on any info but any questions, please ask as i will be checking on this for the rest of the day.
Edit: One thing i forgot to add, i tested coil packs on all 6 and got a range lowest 2.6 ohms highest 4.4 ohms
I was told that as long as they average about the same, it shouldnt be the issue. I hear and read alot about FP relay but not exactly sure how to test to see if that could be the issue.
