I was parking the Z last night and when I was reversing it into the RV parking on the side of my house the radio went out and came back on. I got it into its spot and let it run, noticed that my lights (inside and out) were all dimming, i had the windows down so i rolled them up and that was the last straw, the car died. The weird part was that i went under the hood and noticed I don't have the OEM Battery retainer bar (I apologize if thats not the official name) and I moved the battery a little and then i saw the security light flashing as it always does if the doors or hood is open. I don't get it, after it died it acted like it had no power (I.E. no lights, radio, power locks, and wouldn't start) then i just moved the battery a little bit (and I mean a little bit like maybe a few cm's) and i got power back and I was able to get the car to start and run! Like perfect. I do have the battery light on, it has been on since i purchased the car last month, it is very dim and most of the time I do not notice it, after about 3000 rpm it goes away for a little bit then comes back on (dim still, always dim). My thoughts are a new alternator is needed, its got a new belt and seems to have good tension. Just want some advice before i spend the $$$$. Could also be connection related, i have not checked the grounds because I need to research more on that, the battery terminals seem good and are not corroded.
Thanks all and have a great weekend!
