ncroiger »
https://forums.nicoclub.com/ncroiger-u181428.html
Thu Apr 25, 2013 2:49 pm
the car is 2007.
I just check the connections in the tail gate to the camera and everything is fine. I also checked the V to the camera and it registered 6V. I don't have an oscilloscope but I checked the Camera output signal AC Voltage and it was around .045 V. From the manual that looks within the correct range, but I can not tell if the signal is correct.
When disconnecting the camera, the display went black, but the sonar sensors still worked. Also no issues with the backup lamps. I also checked several pins on the backup camera control until and everything looked ok in terms of voltage and grounds as well.
When the camera is connected, it total snow on the display with the guidelines. I don't get any image from the camera, just white snow/static.
Will an oscilloscope tell me if I have the proper output signal when I compare it to the technician manuals? or should I just go with an educated guess and get a new camera?
Thanks for the help.
