Your not gonna find much of a differance with an aftermarket rear sway bar, other then significant understeer. The torsion beam has what nissan refers to "a rear stabilzer bar". This magical bar is inside the torsion beam, stiffening it, causing much less roll, then without that bar.soulever989 wrote:@ABNRML4U: I did see that, and I do know that most parts for B16s fit on every year's model (for now). But I believe Stillen's website lists the rear sway bars for the B15 sentra (like wanner says). DO you think they might fit the B16 too? Maybe that's why they listed it as 02-07?
Incorrect. An aftermarket rear sway is VERY effective on Sentras in removing any remaining understeer. The lift-throttle oversteer effect that is relatively easy to induce on Sentras gets even more accessible - i.e. a good aftermarket rear sway will help the Sentra's rear rotate even better. It's definitely a good mod and I was pretty close to getting one before I traded my Sentra in.djtorello wrote:
What someone should do, is create a brace for the top of the shock mounts. Reason being, under heavy cornering, the shock mounts flex a bit. This is quite normal on most vehicles. However stiffening those shock mounts, results in a more predictive geometry, and thus, better handling.
I concur. Ive been trying to search Renault forums, but the language barrier is difficult to get around. I keep a tab open for a Gogle translation, but its soo time consuming.nametakennow wrote:I've heard of this issue with Stillen mislabeling parts as for 02-07 SE-Rs/Specs. If it says that (I haven't looked at their site lately), then they actually meant 02-06.
It'd be interesting to see what parts are available for the Megane abroad that could be used on Sentras here. I'd imagine that would broaden the aftermarket available for Sentras significantly.
