b16 question
wingedmark
Car: 2007 nissan sentra 2.0s
does anyone know if it is possible to port and polish the 2.0l engine. if so, does anyone know a good place the does it or where to find a good place to have it done.
djtorello
Car: 2008 nissan Sentra SE-r
wingedmark wrote:does anyone know if it is possible to port and polish the 2.0l engine. if so, does anyone know a good place the does it or where to find a good place to have it done.
Ive done it on a friends 2.0L. Not much needs to be done, Though a gasket matching is a VERY good idea. As where to have one done, check either google or your local yellow pages for a machine shop. Call around, and ask for estimates.
If your intentions are for a P&P, i suggest its a good time for 1mm oversized valves, Mild cam grind, bore out your TB, and install new throttle plate. Also good time up upgrade and Index your spark plugs. But its up to you. Just some things i would look into if your gonna pull the head.
djtorello
Just as a small peak, i have quite a bit of experiance with both the 2.0L and 2.5L.
Here you can see the gasket differance from where the intake manifold meets the head. v
Also as a suggestion, here is a pic of the Throttle body. Do you see that bump right before the butterfly? Smooth it out, for better airflow transision from intake pipe to tb, to the little air diverter on the entrance of the intake manifold, then onward to the rest of the plenum.
wingedmark
djtorello, did you do that yourself or have someone do it. if you did it yourself is it hard to do.
djtorello
wingedmark wrote:djtorello, did you do that yourself or have someone do it. if you did it yourself is it hard to do.
Its been about 1.5years since those pics. I did it myself, but then again, i was working for a machine shop at the time. Its not hard, But if you have little to no experiance taking apart and re-assembling an engine, i such u have it done by a professional.
wingedmark
i will probably have it done by a profesional this summer when i am back in WA.
aebstract
Car: 09 Sentra SE-R Spec V
I have full access to a machine shop, do you know of any guides that show the steps involved? What benefits from doing this? On the throttle body, can that just be sanded down?
wingedmark
i think it helps to have an air bench to see the airflow and know where to grind. i was reading up on it a little bit last night and found that it has an average gain of about 10hp but if done wrong can cost about 10 hp.
djtorello
correct.
The hump in the thottle body can just be sanded down. In the SE-R, the hump is a bit less defined, and ill explain that in a little bit. Also the 2.5L has a much bigger tb. http://www.allsentra.com/viewtopic.php?f=28&t=823
As for basic port matching, you just really need to see what casting marks can be removed, and places where the gaskets dont meet up properly, can be fixed, by either making the port larger to match the gasket, or modifing the gasket, to make in match.
