B13 front strut mounts?
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
I've got some binding in mine and suspect that the bearing is bad. I'd like to replace with these:
http://www.tirerack.com/suspen...d=all
They can't tell me if the mount comes with the bearing of if I have to order the bearing separately.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You will have to order bearings separately. Either from nissan or try Greg @ http://www.gspec.com.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Ordered! Thanks again man. Come on over to the SR20DET powered B13 thread!
zer...hread
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
I noticed some very slight wear on the inside of my tires today. I'm thinking about picking up some cam bolts. Greg wants 80 bucks for 4 and I don't need the rears. Tire rack wants ten (or twenty depending on which ones you buy) per bolt.
My question is: the twenty dollar bolt states that it replaces both upper and lower. I don't know what it's talking about? There's only one bolt that I know of. And of course tire rack can't tell me what the deal is either. I only need a little adjustment so I'd like to get the ten dollar bolt (1 degree of adjustment)
Thanks in advance RED! lol
RED_DET
Vendor
2011 Infiniti G37x
I have the tire rack bolts, you only need 1 bolt per side to get the adjustment and that would be the top bolt where the strut mounts to spindle. There are two bolts there, but no need for a cam bolt in both. Just buy two, put one in the top bolt on each side and have an alignment. If more adjustment is needed than what the bolt allows, bore out the strut hole "slightly" and try again.
