RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Fri Feb 05, 2010 10:29 am
You can go with NX2k calipers/brackets/rotors. But I learned that after adding some boost, that setup is borderline not enough. So I went with Wilwood 4 piston/11" rotor setup in the front. In the back I plan on going with 90-94 Maxima calipers and redrilled to 4x100 rotors, it is a direct bolt on. Got anymore questions let me know. You can't run the nx2k brakes on the se-r stockers with out using a 5mm spacer. If you go wilwood, 15" wheels are a must and not all of them clear either.
