VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Mar 26, 2026 8:32 am
No, the bladders are capacitive and not resistive, and there's a big glom of wires connecting the bladder to the controller. It's an "assembly" and not really meant to be diagnosed. If you find broken wires then it's fine to repair them, but other than that it's a bust. The bladder and controller are part of the seat cushion, and on gen1's the cushion is part of the seat frame, so yes, you pretty much need to replace the seat. The frames are about $1000~1300 online and most of the part numbers are still available, but you need to transfer the back cushion and all the trim hardware. Not rocket science but it isn't easy either.
