I removed the three 12 mm bolts so I can separate the shaft from the carrier in the pictures below. As you can see the old shaft parts are rusted together. I tried to break it free using a screwdriver and hammer. With the car on a jack stand, I really can't get much of a swing on a hammer and chisel or screwdriver to break this part free.
Do I need to use an air hammer/chisel to break the axle free from the carrier unit?
I may need to spend $200 on a compressor and air hammer to complete this DIY job. LOL
A picture of the old unit that I'm trying to separate.
The new unit where the axle bolts to the carrier.
Can anyone advise on the issue I will have separating the driver side axle below.
