Don't know if anyone's tried. It would be interesting, although I don't think it would work. The function is controlled by programming in the BCM.XterraVersa wrote:Does anyone know if you can put the auto-up/down switch on the other windows?
Sure would be nice if the BCM could be programmed to automatically lock the car doors when driving.Ever Victorious wrote:
That happened to me after I did my intake. Then about two months later they randomly started working again...reyes1212 wrote:^^^ yeah
After removing the battery, mine doesn't work anymore...and I have no clue how to fix it.
I have a real problem with those. Every car I have used with those has a major flaw. When you try to open the door, they don't unlock. I see that as a major safety hazard. If in a crash you had to get out fast, you may be so disorientated & panicced that you can't unlock the door. I guess that is true about all cars I have driven. It just doesn't make sence, but I would rather lock the car, than some computer.vpnavy wrote:
My early 80's (80-84) Subarus had those kinds of switches you are referring to. But I suppose in this day and age, everyone has to have everything controlled electronically instead of mechanically. *sigh*XterraVersa wrote:Damn, I was hoping it was the switch, not a computer control. I have seen switches that work that way without a computer.
thanks man just like i gave that advice on the tpms, thx to you tho lol THANKS phew here goes!JoshH wrote:It is in the FAQ at nissanversa.org. You roll up the window and then hold it for about 10 more seconds. It worked for me and I frequently disconnect the battery.
I just installed an alarm over the weekend (viper 5002) and it has autolocking doors when the ignition is turned on.
from your owners manual...reyes1212 wrote:yeah that happened to me too, but hasn't "relearned how to yet"
