Auto to Manual Swap
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Bloodman324
Car: 1981 Datsun 720 Kingcab 2WD Automatic
Hey guys i know its been awhile, but I've been busy with my new job and everything, but i am driving my truck again. It may not be finished but its good to be driving it again :) Anyways, i just bought a 5 speed transmission out of an 82 or 83 720 standard cab short bed. I've got everything i need, but what i'm not sure of is if it'll be a smooth swap (like if it will bolt right up with no problems) and if ill need a different length drive shaft. Any advice would be appreciated. Thanks
dirtdog
Car: 85 Nissan 4x4 King cab
Have you pulled the carpet and seen a plate on the floor? As far as the drive shaft length, Just measure the orig trans and the replacement. Should tell you all you need to know for length.
Good luck!
Bloodman324
Yes i have seen the plate, and with a little research i found that the shifter position should be the same. Ill be picking the transmission up tomorrow and will do some further looking and comparing. i will post up picks of the swap once i start. This will be my first ever time doing something like this and any advice to help me get ready, prepared and any precautions i need to be aware of while doing this will be greatly appreciated.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
yes lots of pics. I would love to do this conversion. I hate slush boxes. its the only thing I hate about my truck :(
Bloodman324
Well here are the pics i promised :) and when i do get around to swapping the transmissions ill be as detailed as possible and lots of pics haha
Ill have the clutch, flywheel and clutch plate all resurfaced before i install them
All covered up until i start cleaning it all up
Clutch master cylinder, pedal assembly, and other bits, nicely tucked away in this beautiful box flat
Well thats all for now, ill keep adding picks as i clean it all up and get ready to swap.
Bloodman324
K quick question for you guys, What exactly are these two switches? I believe the one up near the shifter is for the reverse lights but what does the other one do?
Top switch
Bottom switch
Did some cleaning
Any information on the switches would be extremely helpful! Thanks :)
dayid
Car: 1986 720
Random guess on the switches (would have to check my FSM later) - 1 for neutral/check to allow the starter to try and kick w/o the clutch in - and the other for reverse lights.
Bloodman324
Ahh ok that makes sense now, thanks, hope i dont have any electrical issues seeings how it all looks like "plug n' play" type. I'll keep all yall posted as get further into it, im hoping to get it done this weekend but idk for sure yet.
Return to “Datsun 720”
