Auto to Manual Conversion ?'s
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Bloodman324
Car: 1981 Datsun 720 Kingcab 2WD Automatic
Alright so i'm debating over whether to convert my Auto to a Manual transmission but i have no clue what all i need to do to convert it. Can someone maybe tell me how this is done? Any help is appreciated :D thanks
PEZi
Basics, you'll need to make sure the new trans mounts up properly etc. and be sure there will be no fitment issues. After you source that... the basics are, of course, the transmission, and then clutch and all related accessories including master cylinder and clutch pedal.
drumaniac3000
Car: 1986 720 4x4
Is the power brake booster the same on both trucks, ie. have the spacer tube off the firewall? If not a swap of the booster/ brake lines may be needed too.
Bloodman324
Well I know the basics PEZI, what i dont know is exactly the parts i will need and how to do the actual conversion. See my truck is a daily driver so i need to figure out all this important stuff so that i can quickly do the swap without any hold backs.
PEZi
Too be honest, I don't know about all the little bits and pieces. I mean, if you need different transmission bolts or anything like that, I dunno. You'll need a clutch alignment tool. Get the fluids ready to go. That's all I can really think of off hand.
Return to “Datsun 720”
