I love it when my audio partner in crime chimes in with good responses...AppleBonker wrote:Based on the fact that you want a ported box, I'm guessing you're looking at something more boomy rather than clean. Two subs would make more sense in this application, as two tens will get louder than a single comparable 12 (even a better 12 at the price point of two tens - though the single sub would likely sound better).
Personally, I'd save up a touch more and go with a vastly better setup. If you can handle the install yourself (it's really not that hard), and maybe build your own box (again, not that hard) you can make out a ton better.
Quick check:
Image Dynamics ID10D4 V.3 = $160 (woofersetc.) x2Sundown Audio SAZ-1000D = $355 (soundsolutionsaudio)
Add in wiring costs and parts for a box, and you'd be looking closer to ~$800 (maybe 850) but this will destroy the RF setup. There are certainly other options, but this is the first that came to my mind...
Definitely more SQ than SPL-- but like I mentioned it does not have to be amazing SQ...rjdmmfl1 wrote:I think you should let us know if SQ or SPL is what you're after... you're a Dj so Im guessing you want SQ... and if so, I'd go with the Sundown Amp and Image Dynamics woofer!
OK, IMO the perfect balance between SQ and SPL wil come with either a riduclously expensive 12" subwoofer that can perform well in a sealed box (critical mass UL12) or two 10's. I gave you the setup early based on 1 10" sub... two of either of the subs I recommended will cost you a bit more than you probably want to spend... remember, you're gonna lose a bit of SQ with a ported box, but you gain SPL... so if SQ is more important, I honestly think 2 x JL W3's or 2 x W6's will be more than enough for what you need... which setup you go with will depend on whether or not you want to have "stupid bass" every now and then... I know I do .. if that's the case ,I would go with the 2 x JL audio 10" W6's and the Jl audio 1000.1 amp.... I doubt you'd ever need to change again...maxentropy wrote:
Perhaps mentioning my old setup may help-- in my old saturn I had dual audiobahn 10" ported box with a Hifonics Zeus 7500 amp. It was nice, but I'd like a bit more SQ and SPL from this new setup-- both equally so.
Thanks guys, really want to get a sub soon so keep the suggestions coming-- I really need my bass!
just listened to that.. I'll give it a listen in the car later... I'd say , if you really want to hear those bass runs being reproduced correctly, 2 x 10" W6's should be plenty...maxentropy wrote:Cool thanks doc.
Doc, do me a quick favor. Go to the link below:http://www.youtube.com/watch?v=PWlvLwLv1f4&fmt=18
Listen to the tune until after :50 in when it hits. That's some heavy bass and I want to hear all frequencies but also I want that shiat going through me like I'm getting kicked in the chest. Hear me bro?
I also listen to slow hip hop on the other end of the bass spectrum but this new prodigy cd will rape subwoofers and I want a pair of 10's that'll handle it and then some.
Whatdya say?
Nice! It's toned bass (I guess thats the best way to describe it). My current bose "back subs aka 6x9s"-- (haha what a bunch of bs) can't handle it.rjdmmfl1 wrote:just listened to that.. I'll give it a listen in the car later... I'd say , if you really want to hear those bass runs being reproduced correctly, 2 x 10" W6's should be plenty...
No, I'm not a fan of JL W7's at all.... by design, they are sloppy subs purely meant for SPL, not SQ!maxentropy wrote:Also, one 10" JL W6 or two?
Does it matter if I get a JL W6v1 or a JL W6v2? Is there any newer versions than 2?
Would you recommend going for a 10" JL W7?
ok, well to be honest(and I think Applebonker would agree) alot of older stuff was designed for raw power... they may not have the most advanced circuitry , cooling methods, etc.. but they produced raw power... my old Rockford fosgate punch 70 amp pushed a system that was louder than my current Rockford setup.... and it was only suppose to be producing 75 watts x 2 ...maxentropy wrote:Could someone give me an idea of how decent the amp and subs I listed are in my post above?
I'm wondering if my old audiobahn subwoofers and hifonics amp is still decent compared to todays stuff.
