Postby
kevlar119 »
https://forums.nicoclub.com/kevlar119-u170127.htmlMon Oct 11, 2010 5:27 am
That is how they are designed - - in groups of 3 in case you need to make it shorter - you just cut between the group. You really can't notice it unless you look closely, but I will keep an eye out for a nicer set. The power/ground wires are pretty small and might be an early failure spot.
