Jimmy9190 »
https://forums.nicoclub.com/jimmy9190-u294982.html
Mon Mar 17, 2025 7:33 pm
I would like to do a coolant drain here at home, I have a 2018 Rogue S, nothing fancy, it's not an SV, no AWD or anything like that. It has 67,000 miles on it now and the sticker in the door jamb says it was built in November 2017, but the In-Service Date is in March 2018. It's a Korea built car so I guess it took a while getting over here and delivered to Florida.
Anyway, the maintenance schedule says replace the coolant at 7 years or 105,000 miles. I am at 7 years now so would like to drain and fill the coolant. I read the FSM page on it, wanted to ask do you really have to remove the freeze plugs from the block and/or drain the block? Is it possible to just crack open the radiator drain and refill it with new coolant/distilled water mix?
I would not mind taking it to the Nissan dealer to get this done if I have to, but I just wonder what does Nissan do for a coolant swap? Do they really use a flush machine and flush out the radiator, block, hoses, all of that, or do they drain and fill the radiator only? I can do it myself if that is all it takes, sort of like the spill and fill CVT fluid swap I did here at home not long ago. I am in Florida, it gets pretty hot here most of the time so I want to get this done as soon as I can.
Also I read the coolant capacity is about 2 gallons of 50/50 mix but is that just the radiator or is it the total for radiator and engine together, so my logic would say if it's just the radiator, I would appreciate if anyone knows the radiator's coolant capacity by itself. I tried Google and Youtube and was kind of surprised there is not much info out there for a DIY radiator drain/fill. My Owner's Manual just says the Nissan Dealer can drain and flush the coolant.
Any help, tips or info is most appreciated. Thanks.
