jt15833 »
https://forums.nicoclub.com/jt15833-u30482.html
Sun Aug 10, 2008 2:50 pm
got a chance to install the head studs and take some measurements tonight.interesting stuff.
units are mmWP = water pump stud, the only one in question
distance from block surface to top of studWP = 102.72Others = 95.55
So our water pump stud sits roughly 7mm higher than the rest. Heres numbers that matter. From here out the only stud we are talking about is the WP, since the rest are assumed to work, or else this would be useless. Pinching theorem.
Distance from block surface to bottom of ARP nut, fully threaded on the top of stud (no head in place yet)-78.05
Distance from bottom of headbolt washer perch (in the head) to the head mating surface-77.49
Thickness of ARP washer2.99 (3 nominally)
Ok so there it is, we essentially have 80.48 mm of material above the block surface, and the threads begin 78.05 mm above the block. With a headgasket there will be even more margin.
For me this is still very close for comfort, but unless there is 2mm + of metal compression (noooooooo way) it should work with this ARP hardware, and no double / beefy washer.
Here's a pick with a different way of interpreting the numbers.
