MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Wed Aug 27, 2003 4:26 am
As some of you know, my car's been running quite rich lately, and I really have no means to adjust it...I was planning on upgrading my fuel system in the future anyhow, and I'd like to be able to adjust the air/fuel ratio.
Now for the questions:Basically, I just want to be able to adjust the a/f to make it run more neutral than rich at about 9 psi on a T3 super 60B (.48/.60).
1) Can either of these units be used with an aftermarket RRFPR programmed?2) Both of these units can be used with stock injectors, correct?3) If I wanted to upgrade to SR 370CC injectors, I could "program" either unit to run with bigger injectors, correct?4) Both of these units can be used with an S14 KA MAF, correct (1995)5) How hard is it to install either of these units?6) How hard is it to adjust the air/fuel ratio for both of these? (ie, do you need separate harnesses, etc) They are both piggy back units, correct? But the S=AFC has an actual display and the Emanage does not?7) Basically I'm looking for ease of installation, and ease of control--I don't need anything crazy, I basically want it to be able to make my car run a little more lean and to lean it out even more when I have to go through emissions, and to be able to upgrade to SR injectors when I wish to. Which do you think will be the best?8) I know the Emanage adjusts timing as well, but the S-AFC doesnt?9) What is the difference between the regular S-AFC, super S-AFC, and S-AFC II?
I'll be thinking of more questions and posting them as well...Thanks!
