Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sat Sep 06, 2003 8:37 pm
Well i was just refering to the mileage on your stock springs, thats all. If you use street cams (not full race, like nismo R4), then you are not really going to need race springs. Shims are important 'cause you need to have the valve clearance at spec, and yours maybe out of spec currently. Raising the rev limit, i think is something you do not need, you are already losing power at 6900, so you would be spending money for nothing. Search for some of the dynoes of other KA's and you will see the power drop off. You can clip the speed limiter wire though... and you'll get more results from that. Going with new fuel programs will help, but that's really only worth the money if you go turbo, or if you're concerned about running rich. Larger injectors will run that way, but they do help by themselves.
