drummerguy wrote: ↑Wed Aug 31, 2022 8:37 pm
Well I suppose I should try a new gas cap first and if that does not work change the evap vent valve. Afterwards do you recommend driving to remove the check engine light or is it better to use the scan tool instead?
Definitely a scanner. Once an evap code goes "past", the ECM needs to run two more consecutive EONV's before it will turn off the MIL. So you're into at least three drive-and-park cycles, and perhaps much more if conditions aren't right. It helps if you maintain between 1/4 to 3/4 in the fuel tank while checking to see if the leak is gone, EONV won't occur if it's above or below that.
