are u trying to tell me that if i use a obd1 intake manifold i wont have wire up the harness to the dash? how does that work...u must not get what im saying, im trying to hook up my tach, speedo, ign, water temp. sensor and the ground wires. usdm240 has the right idea, its just that on obd2 they changed those colors he mentioned.
USDM240 wrote:there shopuld be about 12 wires that come from the ECU and go to the body harness connector under the dash. if my memory serves me correctly, you only need to use 5 of them. the rest can be taped off and out of the way. orange, yellow/green stripe, yellow/red stripe, black, and blue/black stripe. match those to the body harness connector and voila.
the obd2 harness is different and i just needed help determining which wires are the ones i need
