evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu May 28, 2009 6:51 am
looks like someone wants to do the Z31 ecu swap onto an S130 ZXT
the lest leaves me with questions, if you want a T4 that implies you want big power, in which case the stock injectors form the Z31 turbo won't cut it, which means you'll need the ecu fomr an 87-89 that can be remapped or tuned with nistune, conzult or similar to use largere injectors
and the 2+2 n/a engine harness should be the same as all the other enginne harnesses, the chassis harnesses got all the wiring changes
lots of info on the Z31 ecu swap herehttp://forums.hybridz.org/showthread.php?t=91250
