haleakalag »
https://forums.nicoclub.com/haleakalag-u205250.html
Mon May 02, 2022 12:14 pm
Thank Larz. My M37 and Q70 have that feature. The problem is it goes like this: 1.I say "Call Gary" 2. A list of several names always then comes up- usually numbered 1-5. Often the names will all be incorrect. Most commonly the top one will be the correct one. 3. I have to say the number of the correct name to call- 70% of the time I then say "ONE". Some of the time I have to say "Go Back", and repeat the name. Other times the name is 2nd to 5th on the list, so one is forced to read down the list while driving. 4. After saying the number on the list, it says " DIALING" and finally sends the call out. If I am using my Iphone in the car, I simply say "SIRI, call Gary" and it says "calling Gary and dials out thru the Bluetooth- infinitely better and the way all new cars bluetooth/stereos work. It is a software program issue, never been improved upon, and identical in the M37 and Q70. One can use shortcut settings, but unfortunately that is what I am referring to here. The standard setup is even worse. Its the same for Navigation commands, but thankfully don't use it here on Maui. "Destination Home" is the only one that works with a single command. The others force one into picking categories (like gas station, restaurant, etc), then picking from a similar list of 5. The choices are always the nearest ones, so never works if using Nav for a farther destination. It does not have recognition of places like SIri- Siri, directions to Joe's Diner. That would work immediately. Just frustrating.
