Any way to disable fuel warning chime?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
stockBC1
Car: 08 Versa SL Sedan
Everytime our 08 versa gets at around 1/4 tank the car will shut down the stereo and start chiming. At first it freaked us out but found after you fill the car up it stops.
Is there some easy fix or do we have to go to the dealer?
frankoV
Car: 2008 SL Sedan, Magnetic Grey, CVT
Wow! Gotta be a dealership issue -- I've been down to the "need gas" light a coupla times . . . no chime, and stereo keeps going strong!
My condolences
kcourtad
Car: 2007 Nissan Versa SL Sedan
mine just puts a light on the dash tellin me to get fuel soon... no beeps or anything...
bdu
Car: 2008 Nissan Versa SL HB
What the hell? Really? I've *never* seen that. I *always* wait until the light comes on to even think about filling up, but all that happens is a light...
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
Ditto, I have an SL and it doesn't do that... I wonder if it's part of a package... do you have the convenience package?
stockBC1
Yeah I have the convenience package. The blinker and stereo turn down really low and then the car starts beeping. It stops beeping when you stop, but starts beeping again everytime you accelerate to let you know you are wasting more gas??? It beeps so loudly that it seems like more of a safety hazard than a convenience.
Modified by stockBC1 at 6:49 PM 9/3/2008
alonsorules8
I found the beep you are talking about but it is not a for a low fuel chime it is a chime to inform you the you E brake/ Hand Brake is still engaged. I would check to make sure that the Hand Brake is fully disengaged and then put in drive and check for said chime. If after checking your hand brake and chime is still there then take to dealer to be serviced for faulty hand brake sensor.
stockBC1
Thanks! But I had that happen once. That lights up the brake warning light also, not the gas light. When this happens the emergency brake is all the way off and the light is not on for the emergency brake. Only the gas light comes on. I'm just going to take it to the dealer.
bdu
BBISHOPPCM wrote:Ditto, I have an SL and it doesn't do that... I wonder if it's part of a package... do you have the convenience package?
I have an SL with convenience. It doesn't do that.
randyshemin@comcast.
Car: 1971 240Z, 2001 Sentra SE, 2008 Versa SL, 1999 Mitsubishi Galant GTZ
bdu wrote:What the hell? Really? I've *never* seen that. I *always* wait until the light comes on to even think about filling up, but all that happens is a light...
The light comes on when the fuel level is low (about 2 gallons left) because the fuel cools the fuel pump in the tank. If it gets too low repeatedly, the pump may burn out prematurely.
Driving Instructor
Car: 2007 nissan versa SL CVT Red
A car with attitude........ NICE!
Everyday, my low fuel light comes on. I cand drive about 75 kms then I get fuel.
I have never heard the beep as you described!
Return to “Versa Technical Discussions”
