pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Thu Nov 03, 2005 11:29 am
If you have spark and fuel, it should start unless your timing belt skipped few teeth. Inspect your timing belt and make sure it is set correctly. If still doesn't start, your injectors probably got clogged with the crap that was in the fuel rail, get yourself some quick start and spray inside the intake and give it a try, hopefully it should get your car started and continue to run.
RafiPULSAR GTR
