Brandon93240 wrote:If the chains don't have excessive wear and the teeth on the gears are still smooth I'd just replace the guides and the tensioners. U can ask an older parts guy at any nissan dealer and sometimes they'll truthfully admit thats all u really need to replace.
Thanks, that's great info. The only reason I was considering replacing the chain and gears is because we'll be right there doing the other work. OTOH, I don't have to worry about messing up the timing.
So, the next question is: how would you judge the wear on the chains? Clean teeth on the gears I can handle, but chain wear is tougher.
Quote » Also I wouldn't trust some of the crap on ebay, they may look like the real deal but considering what will happen if something fails is it really worth saving $150. [/quote]That's why I posted. I've found a lot of stuff on Ebay to come from the same manufacturers as OE stuff, down to the part numbers. I've also heard of horror stories, and I thought y'all might be able to help me out (which you have).
Thanks again, and have a good one,Mike
