klattr1 »
https://forums.nicoclub.com/klattr1-u1743.html
Fri Sep 05, 2003 7:46 am
i figured i would post a few pics.It runs great so far(i've been only boostin up to 5 psi until it was fully broken in)I will be at the dyno and turning up the boost in the next two weeks. Wish me luck!Setup=-t3/t04e 60 trim with .63 ar turbine w/ stage 5 wheel-Fmax manifold, intercooler and pipes, Fmax downpipe with 2.5" to 3" transition and steel braided flex piece to Apexi N1 3" catback-ATPwrap inconel heatshield for turbine(3000 degrees farenheit)-Greddy Type S bov and HKS standard wastegate 5.7psi spring-300zx TT fuel pump-MSD 72 lb injectors in Jim Wolf fuel rail-93 mustang cobra mafs with Jim Wolf ecu programmed(stock fp)-JE 8.5:1's and Crower rods-Jim Wolf 256 duration cams-Cometic MLS headgasket-Blocked bored 20 over with torque plate, 5 angle valve job, micropolished crank, no port and polish on head-Clutchmaster's stage 4 clutch-Autometer 52mm boost, oil pressure and egt-Greddy Profec b boost controllerTurbo5 Turbo9 Turbo10 Turbo11 Turbo12
