DALAZ_68 »
https://forums.nicoclub.com/dalaz-68-u62157.html
Mon Nov 12, 2007 9:20 am
hello fellow NICO forians...
heres my issue
Chassis: 1990 240sxEngine: 1996 engineproblem: bogging out at 3k rpm under load (when in gear), not reving up smoothly
now be4 i get jumped at here is wut ive done so far to avoid asking this
Compression test: 190 190 190 178airleak test: tight as a virginEGR: blocked off completely by ebay steel plateTPS: good (borrowed from friends car) working TPS set at .5 at idleInjectors: working properly, even used stethescope to hear emSpark plugs: NGK V power ( ithink) were brand new now have blow by and whitish tip, which means running lean i believethermostat: newplug wires: new NGKTiming: Stock 20BTDC settingfuel system: new filter,strainer, and pump FPR reads 40psi at idleMAF: proper voltage and works great, borrowed from same car as TPSGrounds: all properly bolted downexaust: no black smoke or any kind that would indicate blown H gasket or coolant leakTemp sensor: did FSM way of checking if it works ( dipping in boiling water with thermostat) and is functioning...ECU: was only throwing EGR nothing else
any body deduct anythign from this...ive gone to other forums and searched here aswell... worst case scenario id have to guess Knock sensor...whihc means ripping off intake mani...which i dont wanna have to do... anyother possibilities im more than willing to listen...
