atlanta_shooter wrote:With all due respect to each of your opinions, why in the world would you do a Mobil 1 Synthetic ATF exchange annually, unless you drive 30K plus annually?? The main reason I did the switch on my '97 J30 was so that I could "extend" the flush/exchange time/mileage requirements. I also think changing a good quality synthetic oil (assuming you do a high efficiency filter change halfway throught the time/mileage cycle) is a waste. This is one area I must disagree with the pundits on the board. Darkened motor oil, esp a synthetic, is not necessarily indicitive of diminished performance.
As a realtor,I put about 25-28k miles per year on the Q.Being that a Q is harder on a transmission than many cars,I feel it is worth the expense.As far as oil,yes a premium synthetic such as Mobil ! or even better,Redline can go many miles longer than dino juice,it still collects dirt from the air and byproducts of combustion.If I was using dino oil,Iwould be changing it every 3000 miles,which for me would be about every 6 weeks!,I feel comfortable using top quality synthetics and changing every 90 days,which works out to be about 5000-6500 miles usually.
