C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Oct 13, 2003 5:21 pm
Not enough and you would absorb more power doing so. Keep in mind energy can not be created or destroyed. So the energy needed to run the A/C system will need to get power from somewhere(likely, the motor). And with the thought that A/C systems are not 100% efficient, you've already wasted more energy running the system than the gains you get. Also take into consideration the amount of air that flows through the I/C and radiator at speed. To cool all this air to any significant amount, you will need a rather large heat exchanger that can maintain a very cold temperature. And then throw in the fact that this condensor can block flow to the intercooler and the radiator. Water or some sort of liquid gas discharged onto the core would do fine. Disgaherd liquid gas will evaporate and supercool the core. Water would evaporate as it draws heat from the core in the process. and best of all, you waste little to no energy and get much better results.
