Amp question
S-14boy
Car: 1998 Nissan 240SX SE
Does any one know how to hook up two amps to run the same subs, I have 2 10" and had one amp powering both and was not enough so i bought another. I bought Monster Cable RCA Y-spliters. But as far as hooking up the power and ground how should i takle this. Distributer block? or can i just run another cable across from the other amps power and the same with ground? if not should I ground both amps in the same spot???I want to try to avoid that humming noise too.
1991240xs
there's an audio forum for this..the mods will probably move your post to it-
nismofan14
You should run the ground wires from each amp to the same spot. To avoid the whinning noise, make sure that you run the RCA cables on the opposite side the power wire is on. Usually does the trick but if not buy a noise filter.
