Amp mounting under the passenger seat
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
kruuth
Is it safe to mount an amp under the passenger seat? Will I drill into anything under there?
frapjap
'07 Subaru Legacy
Probably just the floor, but my suggestion is to take out the seat, pull back the carpet and hit the floor with a punch in the 4 spots you would mount the amp. Go underneath and see if any brake or fuel lines are in the way.
kruuth
I looked and I don't see anything under there. I'm thinking I'm going to mount two points to the car and weld in a bracket so the amp "floats" slightly off the floor. Can someone elaborate more on this?
Return to “Versa Technical Discussions”
