adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Sat Jan 10, 2009 8:31 pm
This kit would bolt on. The only thing thats really different between the 2 cars is the way the intercooler piping would be run through the altima's bumper, and the downpipe from the turbo to the exhaust, that would have the clear the oil pan. However, I wouldn't goto ebay for this. Looks around at local places that do Nissan modifications. They should be able to help.
As LongBeachCoupe (LBC) said, we finished the first turbo for the CVT back in July. It lasted for about 2 weeks, then it overheated, and grenaded itself. After the transmission was replaced, we went at it again. This time with a massive transmission cooler, temp gauges, and an array of aluminum heat shrouds . Since then, my turbo coupe has now lasted 2 months without any problems. My first thought if you were putting this kit on a CVT would be to make sure you keep the transmission, and engine bay as cool as possible. Heat is the failing point of this kind of setup. Good luck!
