Hello,
I have a 2010 nissan altima with 180k on it. It was running fine so far but the other night it won’t accelerate from red light. I floored the pedal and it took a while to respond. I parked my car on the side to see if it happens when the transmission is not engaged but there was No difference. I checked air filter and some hoses to see if there’s vaccum issue. Anyways i turned it off and after a while it started working fine again. I cleaned MAF and throttle body but it behaved the same. It works fine when cold, and starts acting up again when it’s driven for an hour or so. No check engine light on the dash. Still hooked up the scanner, it gave P2A00. Another thing, when it picks up acceleration it moves fine. It’s hard to move from dead stop. But no issues around 40-50mph, it responds well after it has crossed 30mph
Any ideas what should i do next, thanks a lot.
