alternator?
tmorales509
Car: 1991 nissan maxima gxe auto
well when i come to a stop the lights dim & the heater gets low, but when i start going the light get bright again and the heater blows harder. The battery is about a year old and the alternator is a little over 2 years old.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yeah, sounds like the alternator to me.
I've gone through nearly half a dozen alternators on mine--all but the original have been rebuilt since you can't find 100% new ones anymore. Not one of the resplacements has lasted longer than 3 years.
Check the voltage with a multimeter while someone else revs the engine. If it drops below 14v ever, you probably need to replace it.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
So Chris, when are you going to stop paying the money, and learn to wind an alternator yourself? Just a few brushes and some copper, and you're all set!
maxhopper
Car: 02 Maxima SE 6spd
If the alternator checks good, it's more than likely a grounding issue. You should be able to get a grounding kit, and fix those problems. It worked on my 4th gen - same symptoms (most noticeable with the AC or defrost on).
A.Tech
Car: 1998 Nissan Maxima SE Black on Black 5-speed, and yes. I know my avatar is a Gen 5... lol
mine will dip below 14V when I hit the brakes at a light. but only to like 13.8 so it is not bad. I have a voltmeter in my car for readings. I bet if has to do with my system draining a lot as well and I may need a new batt and at least a 1.2 farat cap.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
1.2 FARAD?! What are you powering? A rave club?
tmorales509
maxhopper, u mean these things. they are from 20-50 bucks on ebay.
maxhopper
That's what I'm talking about. You can do one of those, or get one form here. http://www.mattblehm.com/enginegrounding.htm
tmorales509
so are they pretty hard to install? how long does it take?
maxhopper
Really easy to do. If you get one from the previous link I posted, the wires will all be premeasured to connect to specific locations on your car. That's the kind I have on mine, and it only took about an hour to install.
tmorales509
hmmm, i dont really like the way they look tho, how they stick out like that, but i will probly get em anyway.
maxhopper
The one from Blehmco doesn't look like an octopus is sitting on your battery.
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
here's you a link for the install. it's a very straight-forward write-up thats easy to understand. just need a few basic tools and your set. install time shouldnt take anymore than 30 minutes or so, but may take a bit longer if your anal about how things look. anyways, here ya go....
http://www.cardomain.com/ride/24211/3
and here's an old pic of my engine bay. basically, you get the idea of how the kit will look.
hope this helps!!
tmorales509
looks easy but i have the vg30e motor.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Shouldn't be any more difficult for our 3rd gens. Different wire lengths but other than that basically the same.
A.Tech
lol... opps. My bad I forgot the /
1/2 farad...
tmorales509
hmm, i dunno if its just me but i cleaned and tightened one of the ground points and the lights dont seem to dim anymore, lol. Its a miracle!!!.lol
