Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Sat Feb 28, 2004 6:01 pm
Autozone can tell you if the alternator is good or bad.
A whining noise is usually the idler pulley. Not too hard to replace. Loosen the tensioner bolt, pull off the belt, remove the center boldt, then pull the pulley off. There are about 3 bolts that hold on the mounting bracket. Remove them, then you can disassemble the tensioner, and install the new pulley and bolts. Make sure the spacers are EXACTLY the same going back in! Should take about 1 to 1.5 hours.
You should be able to hear the starter, if it is dragging. When you start the car, there should be a lingering noise, like a grinding, or a pinging. Usually, the dealerships are prety accurate, on their suggestions.
The starter and alternator are not that hard to replace, if you have access to a lift, or som really high jack stands. Be sure to disconnect the battery, before you start on either one.
