yourmomsrps13 wrote:
yes, first pic (wire colors White / Red / Blue / Yellow / Green) IS the fuel injectors dropping resistor connectorQuote » i hope this helps me get this figured out[/quote]the second one looks like the coil pack subharness connector, this goes to the coilpacks. It would have Red, Red/Blue, Red/White, Blue/Red, and Red/Green wires on it if thats the case.
However, it looks like you have it plugged in correctly to the coilpack subharness (the dropping resistor wouldn't have that black loop, but the coilpack subharness does), not the dropping resistor, so where do you have the dropping resistor plugged in?
If you look at the links I provided (assuming you know how to read the wiring diagrams, which can be a bit mind numbing to just look at) you'd have been able to see this.
