RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Mon Feb 14, 2011 4:36 pm
How much power do you have? That will affect your rear camber.
For an NA KA setup, I'd probably shoot for .1deg of toe in front/rear and 2.5deg front camber and 1.5-3deg rear. The more power you have, the less rear camber.
My last coupe was super low, and I had to run 3deg or more front camber to get it to wear evenly*. The rear had a little more then 3 deg and I needed less because my tires were wearing out on the inside only, even when drifting. But it did make it easy to slide even with a NA KA.
Just start out with that and see how it does. The most important part is evenness and not having any loose parts.
*The front needed more camber on track to get the front tires to wear correct. On the street 2-2.5 would have been better but I rotated/flipped my fronts a lot since I used to work at a tire shop.
~Alex
