sdtouge »
https://forums.nicoclub.com/sdtouge-u17787.html
Wed Mar 16, 2005 4:15 pm
thanks for looking,
i have a couple problems, 1 is i cant get the lower timing cover off to put in a new water pump, and the other is the alignment pins are being really stuborn.
1)got off all the bolts, the only thing i didnt remove was the crank pulley, someone said that it wasnt neccesary. its wiggling around nice, but keep getting stoped by the water pump.
2)take off my old clutch, sand and clean flywheel, then try to pull a laignment pins and it wont go. to verify (i am 99% pulling on the right thing. there are three of them right now, and they go next too the bolts when you bolt them in)should i hit them up with a lighter or a torch type thing?
really getting stupmed here, kinda bumming me out. anyhelp is apreciated!
thanks,matt
