air intake replacement
qx4er
what is the latest and greatest. frankencar, roar, k&n. if you have an opinion please share and explain why you think so. thank you.
Chedman13
Car: 2003 Infiniti FX45 AWD VK45DE
K&N without a doubt. Most gains and made the best.
I've tried several and ended up ebaying all of them. Don't make my mistake. Stick with K&N unless you need the looks of an aluminum tube.
If you want all stock connections and everything to fit perfectly, there is no other choice than K&N. The tubing resists heat, there is a heat shield, brackets made for the car, great installation instructions, etc....
I have a Stillen Intake only because I got it free.
surge
The Roar Filter design looks pretty good, IMHO. I checked the website and the Carbon Fiber design seems to be a good addition to shield/resist heat. Although it's not a true CAI, it looks like a solidly built intake.
usc45
Car: 2001 Mercedes W210 E55 AMG
i saw that MAC Performance came out with an intake for the 00-03 pathy w/the 3.5. it should fit the qx's as well i believe.
http://www.macperformance.com/...D=748
Chedman13
I tried the MAC intake. It doesn't have all the vacuum hose connections. I don't suggest it for that reason. You can easily drill holes and make them if you want, but I'd rather have the K&N that does.
USC45, I have a 01 QX4 and 00 Prelude also, minus the hot girl on the hood. Sweet looking rides, ebay has a lower billet grille for the bottom bays if you're looking for some.
the pictures are pretty bad (old digitial camera).http://www.cardomain.com/memberpage/737249
usc45
thanks. i do like the K&N intake as i have one, but i just figured i'd throw that MAC one in the mix. the prelude belongs to kim, not me. i also saw that billet lower grill on ebay, but the seller was charging too much for shipping. thanks for the heads up tho.
skylinex
Car: 2004 350z
Just wanted to say, The Roar I have in my 350z is a True cold air system. The stock 350z air box is a true cold air, and the RoarFilter replaces the stock 350z airbox puling in air the same way. Check out the roarfilter.com site for your self. If you didn't notice, the RoarFIlter pulls air only from the front like the factory 350z airbox. It just does it alot better.. So well in fact I ditched my old CAI on my 350z. You can keep your K&N. I'd rather show off my RoarFIlter on my 350z VQ series 3.5 6.
Modified by skylinex at 12:58 AM 2/20/2005
skylinex
Car: 2004 350z
Oh by the way, on my 350z I used the heat resistant race Silicon Fiberglass pipe coupler hose rather than any aluminum one? But doesn't K&N use painted steel piping for your Pathfinder Qx4 . It is hot to the touch on your Qx4 ?
Modified by skylinex at 1:00 AM 2/20/2005
skylinex
Car: 2004 350z
350z install photo. - Check how the cold air gets to the RoarFilter, like the stock airbox. The cold air is completely encased. It's not a side shield . Looks like It belongs on the 350Z . It leaves me speechless everytime I pop the hood.
Modified by skylinex at 1:02 AM 2/20/2005
Axelpkt
Car: 2002 Nissan Pathfinder 5spd
Has anyone tried the frankencar intake in a 01-04 pathy? i'm thinkin bout getting it for my truck
QX4Pgh
Car: Gearhead
I installed the K&N FilterCharger on my 2001 QX4 yesterday. Went very smooth- all the hardware and instructions were perfect. All hoses, wires etc. fit just right. There is some apparent "SOTP" performance inprovement- at least better sound. I recommend the product.
rhpratt
Car: 2001 Pathfinder 3.5
Has anyone responded to you on this? I'm also looking at the Frankencar intake. Let me know, thanks... [email protected]
larryt
Car: 2002 Nissan Pathfinder LE 4X4
That's a nice setup on the Z. Unfortunately, the Path/QX4 stock airbox doesn't draw air from the same spot, so a "true" CAI is tough to achieve.
I have had the K&N Aircharger on my 2002 Pathfinder for about 8 months. NO MAF PROBLEMS TO REPORT. It was super easy to install and sounds great. Minor performance increase and minor increase in MPG. I got an email from K&N a few weeks back saying they had released a model that is emissions legal in CA. It looks to be exactly the same as the one I have and I'm working on getting some paperwork from K&N to help on the next smog test (not sure if it's necessary, but just being cautious).
I would definitely recommend the K&N, especially if combined with an exhaust. Certainly not knocking the others, since I almost went with the Frankencar, but couldn't reach them to actually buy one.
NISTECH
larry cold air intakes are legel in california now, only thing thats not legal about the set up is if you remove any of the sensors from the intake ducting that were in the original intake.
larryt
NISTECH, thanks for the info.
