it should. Only a few mm off from the throttle body placement. Everything else is the same.Pacman20 wrote:Do any of you guys know if the Weapon-R intake fits the B16 Spec V, the website only says "sentra". Thanks!
Doesnt matter. Both Intakes have the same results. Nearly identical setups.Pacman20 wrote:Would it make a difference if it was for the 2.0? Also which one would you recomend the K&N or the Weapon-R?
