Aftermarket sun visors for Rogue Select?
RickFlorida
Car: 2015 Nissan Rogue Select
Hi everyone. My wife has a 2015 Rogue Select that has been a great car since purchased new. It was assembled in Japan and has never had a problem other than basic maintenance. It's starting to show it's age and I'm usually good at sourcing parts and fixing things as needed on all my vehicles but I can't for the life of me find aftermarket sun visors to replace the worn out/sagging sun visors. It's a 2015 Rogue Select. I only see after market sun visors for Rogues that have the wires/light in them so I I'm starting to think there are no aftermarket sun visors for the Rogue Select? I'm not spending 400 dollars on 2 oem sun visors but it's getting hard to safely drive the car the sun visors are sagging so much.
Is my only option junk yard then? Thank you.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I don't see any aftermarket either, but there are tons of used ones on eBay for under $60. Use the Nissan part numbers to search (plug your VIN into NissanPartsDeal.com if you don't know the right numbers). There's also no reason you can't plug illuminated visors into a non-illuminated car. They fit in the same hole, there just won't be anything to plug them into.
RickFlorida
VStar650CL wrote:
Thu May 07, 2026 8:38 am
Thanks for both ideas. I didn't think about how they after market ones for regular Rogue with wires in them might still physically fit. I think I may try that. I'm worried if I bought the used oem Rogue Select ones, they are worn out and will sag too. thanks!
VStar650CL
Technical Expert
:dblthumb:
Return to “Rogue Forum”
