Like it says, im looking at picking up a set of cams but do i need adjustable cam gears or can i use the stock cam gears from the stock cams?
Is it tough to get the stock gears off in good shape?
Post by Ca_Silvia » https://forums.nicoclub.com/ca-silvia-u34581.html Thu Sep 25, 2008 5:07 am
Post by boost_boy » https://forums.nicoclub.com/boost-boy-u2853.html Thu Sep 25, 2008 7:55 am
You do not need a set of adjustable cam gears for aftermarket camshafts. You can use your stock cam gears from the stock cams to gowith your aftermarket cams.Ca_Silvia wrote:Like it says, im looking at picking up a set of cams but do i need adjustable cam gears or can i use the stock cam gears from the stock cams?
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
