silverboy wrote:
I liked that unit as well, I had my eyes on it, but the fact that you have to run cables to the top/visor will be a pain. Also, I don't think I would like that unit hanging off my visor. I had the center area in mind for that install.
Howedy Silverboy.. So... the one thing that causes me to pause with the unit you found is mounting. I see the holes in the base. The idea of screwing it to anything inside my Rogue causes me to shudder.
Getting wire to the sunvisor area has never been a problem for me ( I simply tuck / wedge) the wires into the crack where the windshield meets the roof pillars and the headliner trim meets the edge of the windshield.
So where exactly do you envision mounting your unit.? Since it opens automatically the only place I can see it going is on top of the dash. Even if you were to use double sided tape or velcro I can't think of a place to install it that will look like a clean professional installation. Except for mounting I sure like the design of the unit you found. I'm hoping you have a cool plan for installation it that I can borrow.
So... as to the backup sensors themselves... will you be drilling the bumper after all instead of using the stick on ones?
Just FYI: I also found this "Wireless" model. Again, it mounts on the dashboard (which I'm not a fan of)... but at least there are no wires to run! It's advertised as designed for "commercial Vehicles" and accurate to within 1/2 inch!
http://www.worktruck-outfitter....html
Modified by Elton Noway at 1:44 PM 8/1/2009
