strangebh73 »
https://forums.nicoclub.com/strangebh73-u87019.html
Wed May 20, 2009 11:52 am
the cvt transmission is designed to slow the car down when you are "coasting" in gear. This feature is actually electronically changable by your nissan dealer. (i know, i have done it. i used to work for nissan) Using the consult 3 you can change how much it uses the engine breaking. ever notice that when you get down to around 15 or 20 mph the car moves free'r? It's changable go to your dealer, complain, problem solved, they tell you that your nuts, keep calling, call district etc.
and on the matter of coasting with a cvt, won't hurt it. the only time you can hurt the trans is by having the car moving in nuetral with the engine off, because thats when the engine isn't circulating fluid via the torque converter.
happy motoring
