For what is worth just wanted to post an update on the stillen tow hook bracket. After less than two years on the car, the paint completely deteriorated/bubbled up. I wouldn't have known that if I didn't remove it the other day. The bracket/plate is pretty thick so rusting is only a cosmetic issue. And considering that it is covered by the license plate, it may be non-issue for most, but still. I will give skene a try this time around.Mjkkb2 wrote:Had it about a year. The quality is very good. This plate is thick and would be hard to bend. I still avoid car wash stations unless it's touch less because the license extends past the plate and it will get bent easily. I would recommend getting it. However, cost of two zip ties sure beats the $85
