My girlfriend has a 1995 240sx SE. KA24DE w/5 speed. Approx 125k miles.
I started doing some work on her car due to her car stalling out when the gas was let off. She had to "strategically shift" as I call it, and have to downshift to at least 2nd, engine brake to 1k rpm's before depressing the clutch. It was a major pain the a**, so I pulled the intake manifold and replaced all the vacuum lines, thoroughly cleaned everything that had carbon and oil residue, and replaced all the gaskets I came across.
Now it's back together and there seems to be (at least) 2 new problems:
It all starts with the resting idle of the car. It won't go lower than 1000 rpms even with the idle screw turned all the way in. I checked the impedance of the IACV and it checked out, as well as the continuity on all the wires up to the main connector in front of the intake manifold. Opening the IACV valve brings the engine up to around 1500. The next thing I checked was the TPS. Again, impedance is within listed limits. If it's turned all the way to one direction to get the lowest impedance at closed throttle (1.4k ohms) and has a smooth increase up to 10.3kohms at full throttle. Having the TPS affects the idle initially, raising it to around 2k rpm's at start up and then it lowers to 1k. The other thing that happens with the TPS plugged in is an afterburn on deceleration. It only happens when the TPS sensor is plugged in; unplug it and the car returns to idle without pops from the exhaust. So... high idle, and after burn. Help?
I've been workin on this for the past couple weeks following diagnosis instructions in the FSM and I'm starting to get a little frustrated. If anyone has some insight on what may be the issue, I'd love to hear it.
A little background on what else has been done in the past:
- TPS replaced less than a year ago
- MAF replaced less than a year ago
- Disty, cap, and rotor replaced less than a year ago
- I recently changed the oil pan gasket, belts, removed the marbles from the tin can (timing belt guides), and put in fresh oil and coolant.
