GQM45s wrote:I thought all infiniti's no matter what model use Bose? I thought that was just a standard brand they used in Infiniti
Thanks for the link but I already checked that and unfortunately the wire colors don't match.VStar650CL wrote: ↑Sun Feb 05, 2023 8:01 amYou can find the complete wiring diagram here starting on AV-51 and a terminal layout for the ANC on AV-44:
https://www.nicoclub.com/service-manual ... 1%2FAV.pdf
The ANC is basically a pass-through for audio from the control head, like an amp that modifies instead of amplifies. So you should be able to tap the speaker outputs to feed an add-on amp with no particular issues.
The colors do match, you're simply not tracing the whole circuit. The wire colors change at the connection from the body harness B18 (AV-56, Red on 3, Green on 4) to the door harness D51 (AV-61, Red on 3, Blue on 4). The ANC is on the body side of the circuit, so at the ANC connector B57 (AV-57) you have the Green on pin 10 and Red on 19. This style of diagram is less convenient to work with than the older ones with the connectors and colors on-page, so when I'm dealing with a lot of wires, I always print out the relevant pages and then mark colors on the main diagram. That avoids a lot of confusion.Lutkis wrote: ↑Mon Feb 06, 2023 12:06 amThanks for the link but I already checked that and unfortunately the wire colors don't match.
I know I have blue and red wires coming from left rear speaker and there's no mention of those colors in there.
Also I'm not that good at reading those diagrams. Do the wires go first from head unit to the ANC and from ANC to speakers?
If so then I would only need to find out the speaker wire colors from the head unit, right?
Ok, thanks! I have to take another look at it and print it out to make more sense of it. I don't really see any use for that ANC unit so I thought of eliminating it altogether.VStar650CL wrote: ↑Mon Feb 06, 2023 5:18 amThe colors do match, you're simply not tracing the whole circuit. The wire colors change at the connection from the body harness B18 (AV-56, Red on 3, Green on 4) to the door harness D51 (AV-61, Red on 3, Blue on 4). The ANC is on the body side of the circuit, so at the ANC connector B57 (AV-57) you have the Green on pin 10 and Red on 19. This style of diagram is less convenient to work with than the older ones with the connectors and colors on-page, so when I'm dealing with a lot of wires, I always print out the relevant pages and then mark colors on the main diagram. That avoids a lot of confusion.Lutkis wrote: ↑Mon Feb 06, 2023 12:06 amThanks for the link but I already checked that and unfortunately the wire colors don't match.
Unless you want to eliminate the ANC, you should be tapping the speaker wires out from there and not the H/U wires. It's pointless to eliminate it if it's working correctly, since your amp will probably be right in the same neighborhood in the trunk.
Thanks but I have a 370GT/M37. The HU isn't that big of a deal to me right now.EniGmA1987 wrote: ↑Mon Feb 06, 2023 8:54 am
Check this thread for info on how to install and wire up any double din head unit to the vehicle. You can buy a 2nd bezel off ebay for cheap so you dont have to destroy your current one too
post6787252.html
Are the wires coming from the HU to ANC low-level or high level inputs?VStar650CL wrote:No, you can simply replace the ANC with your amp. The ANC inputs come from the H/U, the outputs go to the speakers, so your best option is simply to locate the amp where the ANC is now.
