marlin29311 wrote:+1 - I mean, it's possible to wire to the box and create a hard line, but seriously why would you want to go through the trouble to do that? It's sooo much work and totally not worth it....
It's possible in the specific sense that there are instructions on how to do it somewhere, or possible in the vague sense that anything is possible, so long as you try really-really hard? ::cue Disney movie::
Is there something somewhere that shows how you would go about wiring into the box? I suspect that it is one of two setups. Either there are many small pin-count connectors on the back of the fuse panel, and its just a matter of finding where to get one of the connectors to add a circuit, or there is one large connector, and its a matter of finding which pins you need to add to the large connector to add the circuit.
Either way, all I want to know is if someone has done this before and has some guidance on how to do it.
